Results 1 to 8 of 8
Thread: looking for a step-by-step diy oil change steps - help
    Feb 2006
    199
    hey yall, can someone provide me with a detailed step by step procedure with lots of pictures of a DIY oil change?
    much thanks...
    2004 S500
    Jul 2005
    SF Bay Area
    1,540
    Cool. I was gonna change it myself too but its not for another 1k miles.
    1997 C280 Sport
    Feb 2006
    199
    YOU ROCK
    2004 S500
    1,719
    Got BRABUS?
    is it better to use the pump or to drain the thing, or are they both exactly the same...
    It doesn't really matter either way. The major point is to get the old stuff out and the new stuff in.
    Personally, it's much easier to change the oil by removing the drain plug.
    Pimpin\' hard with the female passenger
    Oct 2005
    186
    Yea, I've gone back and forth on whether or not to purchase a top side vac, or just do it the old fashioned way. (Since I haven't decided, I continue to pay my mech to do it.) HOWEVER, now that I see 714guy's clear write up, I'm going under to do the task. BTW, I've never noticed drain pans that hold over 5 qt. Are they available at an auto parts store?
    \'99 C280 Sport, Brilliant Silver w/ Xenon High Intensity headlamps/ most options
