Are you changing them to aftermarket speakers? if you are, get some 5 1/4 if you plan on using the factory brackets. All you have to do is pry open the mesh, pop the trunk and push the tabs in, and just shove them out. You have to take a really small flat head screwdriver or knife and pry the factory speaker out, and replace it. Now you can't screw the speakers because it won't sit in the hole right. but you do have to either glue or drill holes and tie wrap the speakers in bracket. and just shove it back in and put the mesh in. If you want to wait till sunday i'll pull out mines and show u how with pics? but it just won't be with factory speakers
