is it in this picture?
Nokia or anyone else who has digital catalog...
I am trying to see if the outer bolt off the rear CAMBER ARM is the same between C220/C280/C36. Would you please be kindly look up the part number? I believe this bolt is also included in the 'REAR WHEEL BEARING KIT'
Any info would be well appreciated.
Regards
Joey,
Thanks for the fast respond. The bolt itself isn't in the image. Perhaps if you look under 'rear suspension' and note the outter bolt of the upper link/ camber link.
The camber link bolts onto to top hole as pointed in the following image... Jeff is trying to find out what size the bolt is. If we can match the C280, C220, and C36 part #, then we know they are all the same size. Thanks in advance!
Sorry about that. I hope I got the right one this time...
If it is the right section is the bolt you are talking about #59? If so they are the same for all 202
A 210 990 11 01 M 10x75 Up to F 698667
it also goes by another pn
A 002 990 28 12 M 12x75, 5x80 From F 698668
Hopefully I pulled up the right one. If not let me know.
The image doesn't show.. Either way, Monday I ll have time to take a look at mine Thanks so much Joey
EDIT... n/m, I must've blocked the cookies off that image site. It shows now.. Yes it is #59. Funny that all of 202s are the same according to that EPC... Jeff found out that C280 has smaller bolt than C43. I ll take a look at my c220 on monday
Thanks again Joey
I just notice the size different between those two part #s. Thanks
Yeah diff sizes for the bolts. Also you didnt block a cookie, might site changed IPs on me and I forgot to update it.
