thank me later. :bunny:Originally posted by kevinzorz
Installed my CAI today, used an AEM dryflow filter, sounds great!
Here are some pics.
this pipe is a 3" pipe that I bought from autozone. The size and bend on it is almost perfect for this car.
I ran into a little problem during installation, turns out that the MAF is 2.75" in diamater, not the 3" I expected, so I had to get a friend to take me back to autozone to get an adapter.
On the other side of this is a 6in pipe with a 22 degree bend, which I also got from autozone, this 6" is then connected to the AEM filter.
The color of the the filter makes it hard to see
Oh yeah, to get the filter in the place you want (inside the bumper), your gunna need to remove this piece, its pretty simple. Just unbolt the bolt, and unscrew the 2 screws inside the wheel well. There are also a few bolts under the bumper. Once the bolts are out, and piece is off, you will have a big opening to work with.
also: do the crossover pipe, you'll notice a difference in throttle response after doing it!
