Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: The custom Grille so far...
    Toronto, Canada
    2,244
    Well I had high.. real high hopes of making a grille for my car some time ago!.. and I started differently by modifying the stock chrome frame, I cut the bottom off and started to work the bottom so it looke dlike it was meant to be only 3 sided.. ive kinda gone away form that idea now and concentrated on a different approach.. although done by others. I did mine slightly different. instead of just putting the mesh in the opening of the chrome frame, I completely made the grille out of mesh. no chrome frame.. just mesh for the entire opening.
    I have plans for another grille soon too, but need to buy some material for that to start building it.
    and this one isnt finished either.. need to do a couple things to it to finish it off, so I can mount it.. and of course paint it BLACK!
    It started off as flat piece of mesh.
    The begings, taking shape:
    Test Fiting:
    Oct 2006
    1,322
    Re: The custom Grille so far...
    looks great.......i wanna make oneeeeeeeeee........hey do u still have those sills for sale still....whats all needed for them?
    May 2003
    4,927
    if somehow the mesh coould be of higher,thicker quality. The concept is great i just keep on seeing chicken wire, ive been looking for good mesh like on benltleys and strut grills
    Sep 2003
    301
    I think it looks pretty cool and very well made. Nice job.
    How do you open the hood now?
    1998 C43 White w/blue & black leather, xenons and more.
    MODS: 18\" SSR GT3\'s 8\'s front/ 9\'s rear. Custom cross-drilled AMG rotors
    w/red calipers. H&R sport springs and Koni yellows, avantgarde grill, custom blue CF interior trim, Llumar
    35% Tint. Clear corners, 2) K&N
    filters. Blaup/Chicago
    7\" monitor DVD w/ 5:1 surround, Pioneer center channel, JL Audio W7 8\" sub w/Memphis 500W amp,
    illum. door sills and alum. AMG pedals.
    MODS coming: It might be for sale.
    Toronto, Canada
    2,244
    Re: Re: The custom Grille so far...
    Thanks. youre talking about the lighted door sills?
    you just need to buy the light up pad part. the kit includes the fornt sills for illumination, the chrome rear sills, and the wirirng harness.
    Originally posted by jnolte
    if somehow the mesh coould be of higher,thicker quality. The concept is great i just keep on seeing chicken wire, ive been looking for good mesh like on benltleys and strut grills.
    yes i agree.. the quality of mesh could be of higher grade.. but I dont know where to get it. this mesh I used is actually the same mesh supplied in aftermarket body kits, to fill the openings.
    but indeed the mesh could be of higher quality, just help with the look. it may look better when its painted?.. or if I were to use some sort of thicker coating on it to kinda hide the pooper quality of this mesh?
    Thanks! lol.. havent figured that part out yet. still in the R&D stages!.. Im either going to cut a small slit in the mesh for the stock tongue to pop through.. or Im going to cut down the stock tongue slightly and drill a hole into it so I can insert a hook through the mesh to pull the latch. not sure yet though.
    Mar 2005
    1,069
    what he said^
    i used to have a grill sortof similar to this on my car,
    but i left the very outside chrome surround.
    to open the bonnet all i did was put a small piece of tie wire out and did a loop over one of the little cris-cros bits in the mesh and then back. and you couldnt see it at all, even when id pop my bonnet to the intermediate stage were the wire poked out just enough to grab the loop it was still hard to see cos the wire was only fine and the same colour as the mesh,
    this worked well
    it might look alright painted black tho.
    and you should keep going with the three sided one, that sounds cool!
    i dont like it but thats just my view it looks to "dun up honda civic" but its a breath of fresh air to al these advatergrades and black numbers
    peace
    Sep 2005
    680
    nice idea! not a big fan of the chicken wire but good for R&D like you said, I guess you could contact some places that restore old british cars and see what kind of mesh they use?
    some continental mesh would look excellent!
    Jul 2005
    1,004
    i think a closer knit mesh, like the ones on jaguar XJR's would be great. yes painted would be nice. in you can make it sit a little further into the car might be good as well.
    May 2003
    4,927
    okay if you paint it black its going to blend in with the negative space behind it and all your gonna see is that support bar behind the mesh, that would be ugly
    Jul 2006
    261
    paint that black too
    Dec 2006
    Norcal
    2,864
    im sorry if I sound negitive but im not feeling this at all. its just missing without that center piece there.
    white 97' C230 (sold)
    white 94' C280 (sold)
    white 98' C43 (sold)
    Tektite 03' E55 (sold)
    Black 86' Porsche 951 (sold)
    Black 98' C43 (sold)
    Jan 2006
    1,260
    You really cant rice up the grill more than that. This is it. Please reconsider it dude. It doesnt look good at all IMO.:dead:
    Jim
    >> My white Greek merC
    Toronto, Canada
    2,244
    thanks for all your input.. good or bad!!
    but I will follw through with this and see how it looks when its done.
    and I do have plans for another grille.. different route with my next idea.
    Jan 2006
    1,260
    Thats good for me then! Experiment all you like!
    Jim
    >> My white Greek merC
    Aug 2006
    274
    i wounder if you could buy that Bentley grill insert and then cut it to fit the 202?
    might be difficult or costly to be practicaly though.
    Devon
    1999 C280 Sport
    http://www.cardomain.com/ride/2398710
    May 2003
    4,927
    im sure the oem bentley grill costs as much as a 1994 c180 with 200k on the clock
    For what ever it might be worth.
    I found this in my travels
    Here's what they say about it.
    Honeycomb Mesh Grille Kits. This is not the cheesy mesh you can buy at the hardware store. This is 1/4" Perforated Aluminum. Available in milled aluminum or powder coated black. Contact us for Applications from $40.00 and up
    \'94 C220
    Black.
    Chaos reigns within.
    Reflect, repent, and reboot.
    Order shall return.
    Oct 2006
    1,322
    im sorry but honey comb would look ugly on a benz.......i don't care what anyone says........thats why there on fords
  21. #21
    and audi's and several other sports cars.
    -JP
    2002 BMW 330ci | 1991 190e 2.3 | 1999 c280 sport | 1992 Volvo 240 | 1980 BMW 320is
    www.leftcoastbias.com | www.tehdriven.com
  22. #22
    Toronto, Canada
    2,244
    thats pretty cool.. but thikn the gaps are too big for the 202, if they had something smaller? whats the site you saw that on?
  23. #23
    May 2006
    1,028
    lol my ford vs your 202 any day of the week. HP, TQ, performance, resale value, exclusivity. It's got leather, climate control, moonroof, etc.
    Only thing the 202 will ever be better at is handling, but my ford ain't no slouch either.
    p.s. the honeycomb grille on my first ford truck looked 100x better than the stock "file folder" grille on the 202
    vs.
  24. #24
    Jan 2006
    472
    this looks exactly like what I did on my car for which I was massively flamed. Good to know people have become a bit more receptive on this forum. I took it off because there wasn't really a good way to route the hood release through it and it didn't look that great after 2 weeks of having it on.
  25. #25
    May 2006
    1,028
    come on man, don't give yourself that much credit.
