Hello Drew,
from experience don't go with platinum in these older motors, the best plugs are Bosch super coppers. you will need more powerful spark so I would recommend getting some 8.5mm core (or larger) magnacore wires, they really help smoothen out spark and make it more powerful, under boost applications the spark can actually be blown out if boost pressures are high enough.
i HIGHLY recommend upgrading your entire driveline to Royal Purple fluids, it will totally transform the car. For diff you will want to run 75w-90 "MaxGear", for the tranny you will want "MAXATF" (it meets all the highest cerfitication levels and is superior to redline). For the engine I would run a thicker weight oil since it will be under quite a bit of stress and its less suceptible, RP 20w-50 is all the protection you'd ever need. Also you can get new stock tranny filter at AZ autohaus.
yes now would be a good time for new fuel filter as well. I highly doubt you will need new fuel pump however, how would also be a good time to upgrade injectors b/c stock ones will probably not suffice. typically you want to go up roughly 4-6lbs in fuel rate at least when going to light boost FI applications. Remember its ALWAYS better to run too rich on FI than too lean.
Now would be a good time to address exhaust while you are at it too. just curious which model car is this again?
