I thought that that was standard on the cars with wood? The wood I got from Drew (expo5.0) came with that piece.
I will run downstairs now and check the part number on it.
Edit:
There wasn't a part number on it...
The black area. I have seen W140s with wood surrounding the black. Does anyone know the part number for this?
Edit:
1999 C280 Sport - 80K
Glacier White/Ash Leather/Burlwood
Look at part #17. There are lots of different versions. I imagine classic is the black plastic, elegance is the wood?
http://www.detali.ru/cat/oem_mb2.asp...SGR=330&SGN=11
1999 C230 Kompressor
EEK...hmm...wonder which one on 17 it could be?![]()
Researched a little. It seems that the 1999-01 W210, and 1999 W140 had them.
Non-sport 99 w202's also had them in the U.S.
Time to head to the junkyard! I think this would be even better than going to the dealer. There is quite a bit of varation in the wood color over time. 99's seem to be darker than 98's from a lot of the pictures I have seen. At the junkyard, you can match it better. The dealer will just order one and you won't know whether it will be light or dark.
