Results 1 to 3 of 3
Thread: Instructions removing fuel rail & injectors?
    Oct 2007
    142
    Does anybody have instructions on how to remove the fuel rail and remove injectors?
    I want to test the injectors, because I think this is causing my hard starts that I have on a cold start.
    1995 C280
    Mar 2005
    1,069
    does your car idle rough or run rough apart from cold starts? because if not i doubt it is the injectors
    Oct 2007
    142
    it runs smooth.. There was another member (NEA) on here that had the same problem, and it turned out that he had 2 faulty injectors
    1995 C280
