I usually use a wrench or an impact socket, but if you are having trouble fitting a tool over it, you are probably trying to take a shortcutyou need to open up the upper arm nut and pull the spindle toward yourself and to get to that point you need to remove the spring safely, either doing it the old fashioned way or by using a spring compressor.
as you can see, there is no such thing as a free lunch so to speak![]()
