Results 1 to 14 of 14
Thread: Wheels problem anyone help ?
    Mar 2011
    2
    Wink Wheels problem anyone help ?
    i have a set of BBS Le Mans in repl. in 19 inch
    specs are 19x 8,5 ET 35 front
    and 19x 8,5 ET 35 in the back
    bouth have the same tyres in 215/35/19
    The question is, they are in 5x100 and i need 5X112 on my 202
    so i need adapters from 5x112 to 5x100 on the wheel
    i can buy adapters of 25 mm but will that make my tyres rub on the fenders?
    and how much will it make my wheels come out ?
    Because the garage said they wont ever fit a 19 inch thats 1°
    and that the wheel would come out too far wich is forbidden here in europe thats 2°
    Thanks for a quick reaction guys ))))
    San Francisco, CA
    2,827
    If I were you, I would sell that wheels and buy one with 5x112 bolt pattern. Those replicas are easy to find
    Mar 2011
    2
    Quote Originally Posted by pnsji View Post
    Nah too much hassle i allready got them with nice expensive tyres so its alot cheaper
    to keep em and buy adapters
    but thanks ))
    In Charge
    Left Lane
    4,534
    http://www.club202.com/forums/showth...dth-clearances
    This link contains another link with a very good calculation too for offsets, wheel widths, upgrading sizes.
    1998 C43
    1994 C280 (Retired)
    Feb 2011
    Boston, MA, USA
    26
    you can reuse those tires. unmount and mount will run you max $20 a wheel.
    Mar 2011
    242
    Heres something you can do,
    Just have to drill 1/2" holes with the desired bolt pattern (5x114.3 in this case), have the back of the hub machined flat for the stud head to sit flat, buy some ARP corvette race studs, and enjoy.
    Here is the exact ARP race studs.
    http://www.summitracing.com/parts/ARP-100-7708/
    Add hub centric rings to center your wheels
    3,221
    Pretty sure if you do that stud conversion you will also need new rear bearings as you cant get that hub out without busting them.
    Mar 2011
    242
    The machine shop will take care of that with a press, its always a good idea to use new bearings instead of pressing in the same old ones.
    3,221
    Is it actually possible to remove the rear bearings without poping the guts out of the outer one?
    Mar 2011
    242
    Yep, It requires a heavy duty press though. Machine shop charges less than a regular shop to do it (bearing pressing)
    3,221
    Ah of course if you press the centre of the inner bearing,its outer would press the outer outer out...^^ not sure why i didnt do that 6 years ago when we did,i think i tried to press the hub out only(not the bearing centre) which destroyed the outer bearing.
    Feb 2011
    Boston, MA, USA
    26
    a stud conversion will save you lots and lots of headache when you swap wheels.
    Feb 2011
    Boston, MA, USA
    26
    hey you couldnt use your old acc "23k"?
    3,221
    hey,yes i could but thought it was time to get away from that given i no longer have a 2.3 or kompressor (+ most of my other forum names are pagz too.)
Tags for this Thread
