Don't know if there are any after market engine mounts available out there. I bought mine from autohausaz
easy DIY. Just search for 714guy's engine mount replacement thread.
Are there after market mounts avail. for the 202? I feel alot of movement when touching the throttle... After something that will soak up that movement and give me better response!
well i wouldn't say its "easy", simple yes, but it's a bit of a pain in the ass if you don't have a tunnel or lift. Just using a hoist and jacks isn't fun.
Completely mad.
haha, yes "simple" is a better word to describe it. I had the car on jackstand (all corners) to the max so I have easy access underneath. Then I used 2 floor jacks to lift the engine enough to ease
the weight off so I can get to the mounts.
having the right ratchet wrench helps out a lot.
I just used autohausaz search and they're giving me nothing for the c180. are the mounts the same with all c classes? or any particular model ?
I have a friend who has a hoist, so if i do this, i have some handy tools!
