Results 1 to 6 of 6
Thread: Squeaky Over Bumps
    Member
    Dec 2011
    Connecticut
    99
    Squeaky Over Bumps
    Recently, I've been driving around with my windows down, and I've been hearing squeaks come from the front suspension. I'm not exactly sure what it is because everything up there is OEM (137K on the car) besides the springs, but I'm leaning towards it being a bad ball joint. If it is a bad ball joint, then to anyone who has replaced it, did you replace it with an aftermarket ball joint or did you use an OEM pair? Thanks for your help guys.
    2000 C230 Kompressor
    144K
    Coming Soon:
    Avantgarde Grille
    Already Done: OEM Wood Steering Wheel
    99-04 Mustang Fog Lights (6000K)
    6000K HID Low Beams
    OEM Sport Shift Knob
    AMG (171) 17" Wheels
    Euro License Plate
    Senior Member 8=Anonymous=8's Avatar
    Feb 2011
    SE QLD Australia
    138
    Try This first
    no idea where you get the food grade lubricant though
    also, not my vid
    Ball joints are not all that expensive either way oem or not, but it's not what I'd suspect first. If you're conflicted go oem.
    I had some squeeks too. They went away mostly when I installed new control arms ( ball joints and the control arm bushings). My control arm failed so I had to change them, didn't do it for the squeeks.
    \'94 C220
    Black.
    Chaos reigns within.
    Reflect, repent, and reboot.
    Order shall return.
    Senior Member W202FTW's Avatar
    Jul 2011
    Boston, Massachusetts
    282
    I only use OEM parts when it comes to sensitive things like suspension or engine related issues.
    Jack up the car, and try to move your wheel up and down with a long bar under the wheel, if you feel some play - that's a ball joint going out.
    2001 Mercedes E430 Sport
    2009 Toyota Camry Hybrid
    Member
    Apr 2012
    San Luis Obispo, CA
    40
    Most likely it's the ball joint because when I swapped out my original suspension with coilovers on my old BMW, the squeakiness still existed. It was the ball joint that was actually bad so I'd bank on that and the advice above. ^
    Member
    Dec 2011
    Connecticut
    99
    Yea you guys are right, I jacked the car up, and realized their is so much play in the front wheels, so I guess I'll be changing the tie-rod ends and ball joints with Febi. Does anyone have a recommendations on which brand to go with, or is the cheaper aftermarket stuff nearly the same quality as OEM? Thanks again
    144K
    Coming Soon:
    Avantgarde Grille
    6000K HID Low Beams
    Euro License Plate
Tags for this Thread
