Page 8 of 15 FirstFirst ... 678910 ... LastLast
Results 176 to 200 of 361
Thread: C43/CLK55 Conversion
  1. #176
    Jan 2014
    185
    Id have to assume the likes of the CLK Black Series and CLK DTM have an LSD, i passed up the chance to test drive a Black Series a couple years ago. As far as i know, there are zero CLK DTMs in Australia, and only one in New Zealand.
  2. #177
    3,221
    here you go 400nm and 510nm variants
ID:	2001Click image for larger version.
  3. #178
    Jan 2014
    185
    later MB 6-speed manuals in the higher torque application run 2.47 rear,2.82 should be perfect for the C43 then?
    With a 55 engine maybe, but i wouldnt want it any taller with the 43 engine in there!!
    Id have to guess 1st in those 6 speeds would be a lower gear than the autos by quite abit, and possibly even 2nd as well, if they are using such a tall diff id say 6th is a 1:1 ratio, or 6th would be damn near useless.
  4. #179
    3,221
    as you say only one dtm here I believe, I have seen it twice and for sale recently! nice looking car.
  5. #180
    Jan 2014
    185
    Just saw that after my edit, so 6th is a .8ish in both. Huge gap between first and second!!
  6. #181
    Jan 2014
    185
    Bet you wish you had half a mil to grab that eh???
    Ive heard two numbers in regards to CLK Blacks here, 30 or 35, which is about half the number of C43s ( including 98 thru 00 )
  7. #182
    3,221
    If I had that much disposible than yus please!
    I havent done too much homework on those ratio's, I figure if it comes from an engine with similar torque curve then I cant go too far wrong...or can I??... that and the fact there is only one to choose from^^
  8. #183
    Jan 2014
    185
    Itll do the job, ill just wait til someone goes nuts and figures out how to get a 7 speed auto in there
  9. #184
    3,221
    I think space could be the main hurdle, the newer 6-speed manual/7 speed auto looks bigger!?.
    Just in case you guys ever replace your timing chain idler pully,its a left hand thread with an oil gallery up one side..dont ever forget that!.lol=(
  10. #185
    Dec 2006
    Norcal
    2,864
    Yea I knew that ... Terribly sorry I feel as if you didn't !
  11. #186
    Dec 2006
    Norcal
    2,864
    Hell with that though, Paul you should join the Volkswagen community!
  12. #187
    3,221
    Kind of felt like it had a nut on the back, you know that sensation when it turns but doesn't get any looser?...well I soon lost that sensation and another one which lasted much longer came along shortly afterName:  Facepalm_emote.gif
    Nice whip man!, I do wonder sometimes why I bother with mb
  13. #188
    Dec 2006
    Norcal
    2,864
    Yea there's no thread left in the block huh! That's reverse thread too, so I have no idea what you can do ...
    Join the dark side!
  14. #189
    3,221
    Looking nice and flat there
    Yeh there's an easy fix, a new block xD
    I'm devising a way to mount it up to my mill and take it out to LHT 18x1.5, then make a C shape insert with LHT 10x1.5 to mimic the 4mm oil gallery. the only complication is removing the hex(22mm) bung in the V of the block to make sure no swalf is left over...it looks like it can be removed anticlockwise but I'm not so sure??. Also the carrier bearing was surprisingly worn on the load side, you could flip it 180 degree's but I think i'll just replace.
  15. #190
    Dec 2006
    Norcal
    2,864
    But LH thread would mean the rotation of the chain would constantly remind it to come loose..
  16. #191
    3,221
    Idler sprocket rotates anticlockwise?(its on the outside of the chain so opposite to crank direction)
    I removed the large oil gallery bung on the V of the block, had to beat on it a bit to get it free but it is threaded and comes out smooth once you break the seal. this gives full access to the area behind the idler pully and there looks to be no way swarf can get anywhere else(some relief haha)
  17. #192
    Dec 2006
    Norcal
    2,864
    Pic of the idler gear please,
    Yea if it sits at the middle of the V it would turn counter clockwise, so a LH normal thread would natrually come loose. No?
  18. #193
    3,221
    Yip sure, will snap some tonight
    Left hand thread should mean it will tighten if spun anticlockwise, which should be a good thing for the anticlockwise pully!.
    Turns out that left hand bolt has an fairly accurate torque spec in wis of "58Nm(+/-m 4.6Nm)", it is 3/4's of an alloy thread with an oil gallery up one side haha. A banjo would have been a better option but costs more i guess.
  19. #194
    Dec 2006
    Norcal
    2,864
    It would turn the same direction as you would turn to loosen the bolt, hence it would come loose.
    Otherwise I don't think MB would have spent the time to put a reverse thread there .. Or I'm I missing something altogether.
  20. #195
    3,221
    your missing,being left hand thread(reverse thread) the bolt turns anitclockwise to tighten, so the anticlockwise pully direction is trying to tighten it!
  21. #196
    Dec 2006
    Norcal
    2,864
    Yep. I'm done.
  22. #197
    3,221
    lol
    That's ok I've started to implement,I'll try not to drill right through^^
ID:	2023Click image for larger version.
ID:	2026Click image for larger version.
  23. #198
    Senior Member Dearlove's Avatar
    Dec 2011
    Perth, Australia
    407
    well first off, f*** you, i was doing so well, selling all my unnecessary car parts, thinking of selling my c36..... now, well now after reading all this i want to either sell my c36 and buy a c43 or turbo my c36.... thanks, thanks a lot
    But good job
  24. #199
    May 2013
    Bulgaria
    203
    Dearlove, have a look at the below links in case you haven't seen them. You may find some useful info :
    http://www.peachparts.com/shopforum/...12v-turbo.html
    http://www.peachparts.com/shopforum/...o-project.html
    P.S.
    Sorry for the offtopic!
  25. #200
    Dec 2006
    Norcal
    2,864
    It seems soo many people are slapping together turbo kits from random dismantler yards! Awesome!
