Id have to assume the likes of the CLK Black Series and CLK DTM have an LSD, i passed up the chance to test drive a Black Series a couple years ago. As far as i know, there are zero CLK DTMs in Australia, and only one in New Zealand.
With a 55 engine maybe, but i wouldnt want it any taller with the 43 engine in there!!
Id have to guess 1st in those 6 speeds would be a lower gear than the autos by quite abit, and possibly even 2nd as well, if they are using such a tall diff id say 6th is a 1:1 ratio, or 6th would be damn near useless.
as you say only one dtm here I believe, I have seen it twice and for sale recently! nice looking car.
If I had that much disposible than yus please!![]()
I havent done too much homework on those ratio's, I figure if it comes from an engine with similar torque curve then I cant go too far wrong...or can I??... that and the fact there is only one to choose from^^
Itll do the job, ill just wait til someone goes nuts and figures out how to get a 7 speed auto in there![]()
I think space could be the main hurdle, the newer 6-speed manual/7 speed auto looks bigger!?.
Just in case you guys ever replace your timing chain idler pully,its a left hand thread with an oil gallery up one side..dont ever forget that!.lol=(
Yea I knew that ... Terribly sorry I feel as if you didn't !
Hell with that though, Paul you should join the Volkswagen community!
Yea there's no thread left in the block huh! That's reverse thread too, so I have no idea what you can do ...
Join the dark side!![]()
Looking nice and flat there
Yeh there's an easy fix, a new block xD
I'm devising a way to mount it up to my mill and take it out to LHT 18x1.5, then make a C shape insert with LHT 10x1.5 to mimic the 4mm oil gallery. the only complication is removing the hex(22mm) bung in the V of the block to make sure no swalf is left over...it looks like it can be removed anticlockwise but I'm not so sure??. Also the carrier bearing was surprisingly worn on the load side, you could flip it 180 degree's but I think i'll just replace.
But LH thread would mean the rotation of the chain would constantly remind it to come loose..
Idler sprocket rotates anticlockwise?(its on the outside of the chain so opposite to crank direction)
I removed the large oil gallery bung on the V of the block, had to beat on it a bit to get it free but it is threaded and comes out smooth once you break the seal. this gives full access to the area behind the idler pully and there looks to be no way swarf can get anywhere else(some relief haha)
Pic of the idler gear please,
Yea if it sits at the middle of the V it would turn counter clockwise, so a LH normal thread would natrually come loose. No?
Yip sure, will snap some tonight
Left hand thread should mean it will tighten if spun anticlockwise, which should be a good thing for the anticlockwise pully!.
Turns out that left hand bolt has an fairly accurate torque spec in wis of "58Nm(+/-m 4.6Nm)", it is 3/4's of an alloy thread with an oil gallery up one side haha. A banjo would have been a better option but costs more i guess.
It would turn the same direction as you would turn to loosen the bolt, hence it would come loose.
Otherwise I don't think MB would have spent the time to put a reverse thread there .. Or I'm I missing something altogether.
your missing,being left hand thread(reverse thread) the bolt turns anitclockwise to tighten, so the anticlockwise pully direction is trying to tighten it!
Yep. I'm done.
well first off, f*** you, i was doing so well, selling all my unnecessary car parts, thinking of selling my c36..... now, well now after reading all this i want to either sell my c36 and buy a c43 or turbo my c36.... thanks, thanks a lot
But good job
Dearlove, have a look at the below links in case you haven't seen them. You may find some useful info
http://www.peachparts.com/shopforum/...12v-turbo.html
http://www.peachparts.com/shopforum/...o-project.html
P.S.
Sorry for the offtopic!
It seems soo many people are slapping together turbo kits from random dismantler yards! Awesome!
