Results 1 to 7 of 7
Thread: Head/fog light electrical issue
    Jun 2013
    WA
    13
    So, this just happened tonight. Went to turn my lights on and drive home, always use the fogs with low beams, and noticed the right side was dim. Strange, but bulbs burn out, so whatever. Then I notice that if I turn my fogs off, my right low beam comes on, but not as bright as the left side.
    Upon getting home and doing more testing, I notice the brights are constantly dimly lit, and when I activate the brights, only the left side works. Also, right side fog light is dim/doesn't work when brights are on.
    Also noticed, that with the actual dim brights I was seeing a dimly light bright indicator on the dash.
    See this video for what I'm talking about:
    Is this common? Headlight switch? Multifunction switch gone bad? Relay? Not sure where to start with this one.
    Thanks everyone
    Feb 2013
    biglerville pa
    783
    sounds like a bad ground I had something of the sort the connections will burn out and corrode could be the culprit
    Jun 2013
    WA
    13
    Any suggestions on where/which grounds to check?
    Feb 2013
    biglerville pa
    783
    all lol or ther could be a short in the wiper switch that sits in the steering wheel collum honestly I would just start tracing wires back it has to be a short or a jump of current
    Jun 2013
    WA
    13
    Well, I still have yet to check my grounds, but, yesterday out of nowhere they started working correctly again. *headscratch* Yay german electronics!
    Feb 2013
    biglerville pa
    783
    lol I think gremlins are germin haha vyah ?
    guy at work has a issue when he puts hiw right blinker on his headlight blinks with it he originaly cured the issue with a new ground this is why I
    suggested this lol when you hit your high beams the ground may be shorting from a bad spot in a wire or whatever
    Jun 2013
    WA
    13
    So, turns out the problem was at the plug to the headlight housing, wiggled it and all was right.
Tags for this Thread
