Results 1 to 11 of 11
Thread: highest rim size
    Oct 2014
    7
    highest rim size
    whats the highest rim size i can put on my 1999 c230? i have stock size 15s, but i was going to upgrade for some low profile tires, i just need help on the highest rim size i can put without having problems turning my car, thanks
    Senior Member Dearlove's Avatar
    Dec 2011
    Perth, Australia
    407
    18's will fit fine
    Feb 2011
    Fremont, CA
    1,900
    i have 18s... widest i had were 9 inch wheels...
    Senior Member 98Benzo's Avatar
    Jul 2012
    Toronto, Canada
    274
    Hey wichipong, I want to run 17x9 next year In the rear, did you have any issues with 9 wide in the rear?
    1998 Mercedes C230 Elegance
    HID kit - 6000k
    H&R Sport Springs
    Bilstein Shocks and Struts
    Black Vinyled Roof
    Tinted Taillights
    12mm Spacers In Rear
    18 Inch VIP Status Rims (18x8 all around)
    Magnaflow 14833 Muffler
    H&R Front & Rear Sway Bars
    Dec 2011
    Perth, Australia
    407
    I've got 18x9.5 in the rear. Under really hard driving they rub, this is in a c36 which has its guards rolled from factory I'm lead to believe. There is still a bit left to be rolled so i may do that
    Feb 2011
    Fremont, CA
    1,900
    Quote Originally Posted by 98Benzo View Post
    no issues at all... i was even spaced out to bring the offset down.
    Quote Originally Posted by Dearlove View Post
    You need to bend up the lip between the inner quarter panel and the bumper, also shave a lot of the tabs there. I run 18x9.5 +15 on the rear.
    Feb 2013
    biglerville pa
    783
    18*9.5 here n u need to role the fender lips and pull out slightly (you can pull it by hand )
    mines lowered 2 inches or so also
    dear love mine don't hit too hard
    all I did was pull the fender out by hand where the front cover and fender meet and did the same on the side by the door (same location height wise )
    took the rub out unless I have 4 ppl and a hard left turn .... lol
    I'm tucking 18x9.5s on the front, it took some work and lots of trimming.
    May 2003
    4,927
    you can fit 20s , if you really want..
    Jun 2015
    Michigan
    11
    the biggest ive seen without major mods is 19 inches. but the tires were rubber bands. probably not the best ride. i wouldnt do that if i were you.
    i drive a 1999 c280 elegance. but i lowered on vogtland springs and bille sports with #3 and #4 pads in front and back respectivly. i could stand to put #1 or #2 pads in front. also I have adjustable camber arms in rear from the diy. They are perfect for centering wheel.
    I HAVE 0, NO RUBBING, at all in any driving condiiton or surface and can turn the wheels in front knock to knock no issues.
    I personally have 18x8.5j 43et on front with a 5mm spacer and 225/40/18 michellin pilot sport a/s 3.
    on rear i have 18x9.5j 43et bolted right on. 255/35/18 michellin pilot sport a/s 3. (shave lug bolts down about 3mm so no parking brake interference)
