if you are in the US, the right(passenger side) should be aimed higher than the left. this is to avoid blinding oncoming traffic, cant help you with the adjustments on those headlights, never used them.
I installed these perfectly and i noticed that my right beam is aiming a bit higher. I found what i think the knobs were on the back. They're greyish with a cross or plus sign in the middle. I thought i had to put a screw driver in it to turn and adjust the beam light. Didn't work. I also tried turning the knob which was really tough. Didnt work either? I dont know how to adjust these.
I email the company and the guy said there should be 2 knobs at the back of the headlight. But never responded after that.
These are the headlights
http://www.google.ca/imgres?q=have+t...w=1920&bih=950
I finally got pictures :
* are those silver knobs my adjustment knobs? because there the only knobs *
*UPDATED*
any advice please and thanks!
Drexel Business '11
How do the headlights look installed lol ? And if they are in the same spot as the factory housing then yes those knobs should be adjusting it. But I never owned a pair of projectors.
^^ andf6789 I kind of figured that but its to the point where its waay up there and the left is pointing down. Difference of each beam is about half a meter?
^^SD202 i just updated the pics. Okay ill try again using a smaller philips screw driver.
Hi,do you still have these headlights? Where did you get them from? Thanks
You can find it here :
http://www.mercwheels.com/headlights...ts-94-00-p-927
