Results 1 to 5 of 5
Thread: AC: Left side blows cold, right side blows hot
    Member
    Jul 2013
    Ft. Lauderdale, FL
    35
    Hello,
    Recently started having an issue with my 2000 C230. Randomly the ac will start blowing hot on the right side (Right vent + right/center vent). It doesn't happen often, but when it does it is very strange. I can try to mess with the fan power or hot/cold settings, and sometimes it self-fixes. Other times I am left to turn the AC off for the remainder of the ride. Does anyone know what this could be? Thanks in advance for any suggestions.
    Apr 2006
    Europe
    752
    have you checked duo valves?
    they get a hiccup sometimes
    Senior Member Chisel86's Avatar
    Aug 2015
    Houston, TX
    127
    This happens to me as well. What is a duo valve and how do you get to it?
    KOMPRESSED
    Apr 2006
    Europe
    752
    duo valve is on the passengers side in the engine bay where the struts are bolted
    there are 2 small cups attached to some rubber hoses, these are the duo valves
    Member DRBC43AMG's Avatar
    Apr 2011
    Land of mountains, banks and chocolate
    37
    Several duo-valves operate the HEVAC. One apparently is a bitch to remove and needs dismantling the entire dash board.
    Diagram of the vacuum operated valves below.
