I think the max wheel combo you can fit is 18x8.5 ET25 with 225/40's ( front) and 18x10 ET25 with 255/35's (rear). Falken tires are available in those sizes. Also, take note that w202 uses 12mm bolt size while w204 uses 14mm, so you will need special bolts.
