check this out
http://www.mobiletoys.com/partners/i...C280&YEAR=1998
I want to replace all my speaker in my 98 c230 but i dont know what are the speakers sizes. does anyone know what are the sizes for all the speakers in a 98 c230.
check this out
95 M3 (US)
87 190E 2.6
95 318is (EURO)
hmm 6" for the rear door speakers??? I need to see that![]()
Past: 1997 W202 C36 AMG
Thanks
How about the rear panel near the windows, what size are those?. it dosent say on the website.
Damnnnnnnnnnnn
Now you guys are gonna make me spend more $$$$$$$
Somebody that has switched out ur speakers please post the size
I don’t wanna do any mod action I just want them to fit right in ..
Thanks !
I want every speaker to be infinity all inside, I just want to make sure i get the write size.
I did 6.5" on the front door (require modification).
5.25" would be easy fit.
for the rear door, i did 4.5"
for the rear deck i don't have any speakers.
what type of mod did you have to do?.
Mike,
I actually had 1998 C230 with non-bose system. This may help:
Front 6.5†(using factory baskets):
Dash tweeters:
Rear Doors 5.25â€
Using Metra kit for Toyota T100 , otherwise, like pnsji said, 4â€â€¦
Rear deck 6.5 fit right in (once you remove factory baskets), for that I installed later on, 5.25†separates, I built plates
View from the trunk
Here is the link if you need to see more details of my 1998 C230 (now sold) http://www.sounddomain.com/memberpage/205992/1
are there instructions on how to remove the rear shelf speakers? im having trouble removing that plastic grill, under the cover, over the BOSE speaker.
2006 WRX Limited
1998 C280
i have a '98 C280 also. I had to have the whole seat and rear deck taken out to replace the speakers. so good luck.Originally posted by ricerokets4life
My car did not have Bose, so I did not really have to remove the seats or the rear deck (though it all was removed later to run the wires and install fatmat lining, and x-over in the armrest).
Rear speakers were taking out by first removing the grills of the deck, then the actual speaker baskets...
D
How do you remove the speaker grills?
I guess I hav the same question...
I would also like to have infinity speakers all around. So if I get it right:
Front door: 5.25'' or 6.5 if I use the factory bracket
Rear door: 4.5''
Rear deck: 6.5'' and I have to remove the factory bracket
Also, are these sizes are for INFINTY speakers?
How do i remove the rear deck factory bracket?.
