Page 1 of 3 123 LastLast
Results 1 to 25 of 51
Thread: air intake
    Guest
    Dec 2003
    587
    air intake
    ok some one explain to me why mercedes has run the air intake right over the hot engine, cold air is better for the engine right ?
    so is it possible to relocate the air intake to the other side of the engine using some sort of mercedes parts ie from a
    V8 or something ?
    May 2003
    4,927
    possible??? anything is possible...
    but you can run tubing down to the foglights for a ram air effect, speedybenz has done this in his C43, also 2phast did this in his C36:
    http://www.2phast.com/C36/c36.htm
    Guest
    Dec 2003
    587
    i like his idea but i think it would be even better with the intake on the other side not crossing over the engine and thus not heating the air as much. how would i go about crafting a new air intake system are there kits or do i have to work on my own.
    Toronto, Canada
    2,244
    The only "cold air intake" ive ever seen is made by some rice company for the C280/36 if Im not mistaken.. the funny part is, its not even a cold air intake.. just replaces the airbox with a cone filter (but still located inside the engine bay... heat!!)
    The only way to go is pure custom.. either fabricate something yourself with some 3" aluminum intake tubing or have a shop make one for you.
    Maybe you could modify one half of an SL55 intake to be used on your C280, and run ducting to the fornt of the car to get cooler air.
    Im making a cold air intake for my C230 Kompressor.. bought the K&N cone filter and an AEM bypass valve.. just need some 3" aluminum tubing now.
    will post pics as I fabricate and of course of the final product.
    Guest
    Dec 2003
    587
    where can I buy this aluminum tubeing what about platic fiberglass or carbon fiber ?
    im not sure about aluminum. any exhaust shop should be able to fabricate a stainless steel pipe though.
    2006 WRX Limited
    1998 C280
    Guest
    Dec 2003
    587
    nice now you have me thinking
    Toronto, Canada
    2,244
    Any large performance shop should sell lenghts of Aluminum intake tubing.
    I wouldnt go with plastic as it would look tacky under the hood.. but if it gets the job done....
    and as for carbon fiber.. I only know of BMW's that has intake kits made of carbon fiber.. maybe find soemone to make intake tubing out of carbon fiber..
    and I dont recommend using stainless steel exhaust tubing for an intake.. aluminum weighs consideranly less.. and looks much nicer. although it does need to be specialy welded.
    Jan 2003
    934
    my friend has a carbon fiber intake on his golf too, but i doubt it would work for your car
    Elvir
    Baaa
    Guest
    Dec 2003
    587
    slammed C where can i get some aluminum in toronto i dont think i can find any in kitchener
    713
    How do compensate for the 2 holes that the intake attaches too into the valve cover that I assume recirculates the air like an PCV valve?
    Autostart Autostarter
    Progress Rear Sway Bar
    USDM Bodykit
    USDM Foglights
    1997 AMG C36 (RIP Thank God)
    OEM Bosche Clear Corners
    OEM AdvanteGarde Grill
    Bilstein Sport Shocks
    Eibach Springs
    Zender rear lip spoiler
    W210 mirrors
    Guest
    Dec 2003
    587
    what are you talking about
    Toronto, Canada
    2,244
    I had been talking to Performance impovements in scarborough, but they want $45 per 18" section of 3" intake pipe... I was hoping to find somewhere a bit cheaper than that.. so Im holding out till I do find someone else.
    Do you mean the diverter valve thats on the side of my airbox??
    Mar 2003
    1,092
    let me see with my friend
    he has a shop and can get metal at cost
    Etienne
    Guest
    Dec 2003
    587
    I dont have a compressor so i dont thing i have that thing that your talking about
    hey mr space dose your friend want to fab up something and send it to me
    Mar 2003
    1,092
    he can fab almost anything, he has all the machine shop equipment.
    Etienne
    isnt steel cheaper than aluminum? and isnt it more resistant to heat?
    2006 WRX Limited
    1998 C280
    Sep 2003
    108
    u could use any material u want as long as it doesn't generate heat steel does affect performance, all the people i know are using plastic tubing covered by the heat resistant material... it doesn't look good but its better performance wise... the best place for the air filter in the bumper u doent have to remove the foglight u could put it next to brakes air duct (is from the other side not the side of the foglight...)
    Guest
    Dec 2003
    587
    mr.space how much are we talking to fab up something ????
    713
    R, I'm not sure if it's the same on the I4's but on the I6's, the intake that runs across the top of the engine has 2 holes underneath that recirculates the air in the head back into the air intake. If I remember right, it won't run if those holes are exposed. I also think in the actual air tube that runs on tops of the engine, near the bend closest to the TA, there is complicated valving in the actual tube. I don't think it's hallow all the way...i could be wrong though.
    USDM Bodykit
    USDM Foglights
    Eibach Springs
    W210 mirrors
  21. #21
    Guest
    Dec 2003
    587
    yah rocky your right.
  22. #22
    713
    Lets take a different approach. Instead of trying to re-route the tubing, why not try to lessen the heat within the engine compartment? I know those headers give off a load of heat. Turbo wrap and a heat shield on the headers might make a difference. Maybe you can turbo wrap the air intake pipe as well?
    Maybe route a intake tube on the TA side to cool down the intake manifold?
    USDM Bodykit
    USDM Foglights
    Eibach Springs
    W210 mirrors
  23. #23
    Guest
    Dec 2003
    587
    this turbo wrap is fire proof ?
  24. #24
    Paul
    Guest
    fibreglass matting,or turbo wrap is fire proof.well,everything has a melting point...
  25. #25
    Paul
    Guest
    sory,its more heat resistant than fire proof to be politicaly correct.
