I'm going to give you good news. I'm 99.9% sure all you did was blow the fuse on the circuit. Check the fusebox for the appropriate fuse and replace it!
Martin
I happen to drop a piece of bread in the car and this piece got dropped into the little hole where the actual cigarrette lighter is sticked into....
I tried to get this piece of bread out using my GERBER (utility tool) and I got the piece out of there alright....but I happened to touch the inner part of that hole with my GERBER....
As I have done that....two things happened at the same time...
1. A spark was observed at the place where my tool(GERBER) touched the inner part of the cigarrette lighter hole.
2. At that time, the glove box was kept opened and the glove box light went out
And after that.....
the cigarrette light won't light.....I put in other devices that hooks into that hole(such as cell phone charger....) and it does not work....
OK.....
First of all...
What did I break??????
I am going to try new light bulb for glove box tomorrow....but for the cigarrette lighter......will I have to get the new ashtray assembly????
and also......is it possible that I messed up the fuse that might be related to this assembly????
HELP!!!
Martin
2012 535i
2005 545i - Retired
1994 C280 - Retired
I will call dealer and ask which fuse it related....
Either the book should tell you or the cover of the fuse box should have a diagram. Try that. I believe the box is in the driver side engine compartment.
Autostart Autostarter
Progress Rear Sway Bar
USDM Bodykit
USDM Foglights
1997 AMG C36 (RIP Thank God)
OEM Bosche Clear Corners
OEM AdvanteGarde Grill
Bilstein Sport Shocks
Eibach Springs
Zender rear lip spoiler
W210 mirrors
