do you have any before/after dynos of UD pulleys on a V6?
Here is the catch, we have to have it made for us. Evosport makes a set of underdrive pullies for all V6 engines. These underdrive pullies free up power.
I believe it was Speedybenz, that suggest a better alternative, underdrive everything with a custom made (and lighter) crankshaft pully. Many of us should change ours anyway (because of the problem with the rubber).
All we need are the specs and a shop to make them.
Evosport says with their pullies you can get 13 hp in first gear, and 9 in second, etc. I think with the crankshaft, we would see greater gains and in all gears.
Everything with Mercedes is overkill, so I see no reason why we can't underdrive out AC/Alternator/Etc.
Lets get this done, then we can start planing on getting electric fans in our cars (this will free up MORE power).
C280Sportster
search. think. do. post.
The rubber is there to absorbed/control the vibration from the engine but on some engine, the pulley still failed. Can you imagine running any pulley WITHOUT the rubber/harmonic damper? I wouldn't do it !!Many of us should change ours anyway (because of the problem with the rubber).
is there any setup for the inline 6 and approx how much i would be interested in get some underdrive pullies
Well I want to have a new crackshaft pully made with the rubber.Originally posted by Linh
I believe Speedybenz had one made without the rubber and he said it ran fine. But he crashed his C280 soon after, so there wasn't any long term test (I could be wrong about the time).
As far as the inline 6, I see no reason why you can't do the same thing. I'm guessing most people here have the V6. So, we can probably get a deal on getting 10 of them made.
If Speedybenz can jump into this thread that would help !
Here is a link where he suggested changing the crankshaft pully:
http://www.club202.com/forums/showth...ght=underdrive
This type of mod exists for other cars, so I see no reason why we can't do it with a Mercedes. Not to mention the fact that MB builds everything overkill, so we can underdrive everything and not lose anything (like AC, amps, etc).
C280Sportster
pending actual cost of this id for sure be interested especially if i could pick up soem horsies in first gear! =)
99 c280 (WHITE)
In the midst of modding.
Only stuff I have seen are for BMW's. The pulleys were featured in European Car and Eurotuner. I have the issues in case you were interested.Originally posted by Renn 208
I believe if we change the Crankshaft pulley we would have the same power in all gears.Originally posted by Denlasoul
Here is a link to evosport's underdrive pulley kit, note this is a 3 pulley kit for V6s and V8s:
http://evosport.com/product/perf/per...html#powerpckg
From website:
"Kit includes water pump, power steering, alternator pulleys and belt. The T-6061 aluminum, hard anodized pulleys account for a 10- to 20-percent decrease in accessories speeds, reducing the load on the engine. The pulleys were good for 13hp (1st gear), 9hp (2nd gear), 7hp (3rd gear) gains on a 2000 E320. (BMW pulleys shown. Mercedes pulleys are black anodized)"
Now if Evosport would just make a crankshaft pulley, we would be set!
C280Sportster
Other options would be to just have a lighter crankshaft pulley made (I don't know if it's true, but I've read that each pound we lose = 2.7 HP, I guess that would be at the crank) that uses a mercedes harmonic damper or have our existing crankshaft pulley made lighter (holes drilled).
Check out this link:
http://benzworld.org/forums/forums/t...nkshaft+pulley
This is for a C230 Kompressor, but you get the idea.
So, if we can save 2 pounds that would equal about 5.2 hp.
Then add the evosport pulley kit and we are set.
Problem is, that pulley list for $650 (from http://www.aspracing.com), so ours would probably be the same. This could get expensive, but it's still worth it.
C280Sportster
You are right. I didn't know you were talking about the inline 6. The V6 is the one that has problem.As far as the inline 6, I see no reason why you can't do the same thing. I'm guessing most people here have the V6. So, we can probably get a deal on getting 10 of them made.
Man...Need some thing for the V6 man!!!!!!!! anyone??? plz!?
Well there might be something for our V6's SOON!Originally posted by MBATF
Next week I'm going to talk to an engineer about making a lighter crankshaft pulley for us.
I will also see if one can be made to "underdrive" our accessories (10%-20%) and take our existing dampner.
Stay tuned
C280Sportster
You guys stoked about this?
C280Sportster
Is there a group buy for the C230k pulley also? Is there a thread for this?
Thanx..
Thanx..
If you can put a group buy of at least 5 or more for the pre-2000 C230K, i knock $75 off per kit.
They have one for the V6!Originally posted by MBATF
I had a lighter crankshaft pulley on my 1999, C280 V6, it was some 6 lbs lighter. I could not detect any increase in vibration or any added roughness to the motor. I would not hesitate to put a similar pulley on again.
The evosport pulleys combined with a same diameter crankshaft as stock would be very good and result in a increase in power and acceleration.
Jeff
