Welcome to owning a W202 Elvir.Originally posted by C280 JR
...the time i earn enough mnoney for my car, something has to happen, and i have to fix that...
Elvir
Things you can expect the w202 to go wrong if you haven't repaired yet...
*1) Wiring harness (before 1997)
*2) MAS
*3) OVP relay
4) Flex disc
*5) Coil ends
*6) EGR tube plug up
*7) lower control arm bushing
*8) Infamous leaking Gasket (happends to 90% of M104 engines, lucky i got this repaired under warranty)
*9) ball joints (Elvir, if your lowering, might as well change these too at the same time)
The ones with the * is a commom problem with pre 1997 C-classes
