for just an oil change.. I wouldnt take it to just any shop to have things done.. Im sure some of the guys in here could recommend an independant shop that knows Benz..
if you take it to mercedes dealer.. your looking at about .6 hours of labour (times shop rate) on a lube service, plus the cost of oil and filter.
maybe $60-70.. not too sure though.
as for the flex A and B services.. these are expensive to get done at the dealer!.. looking at around $200 for an A service and $300 for B service plus whatever extras you may need.
the B service is the "major" service.
they are important to have done.. but most of the things involved with either service is related to inspecting every component on the car, as well as oil and filter changes.
depending on mileage you may need extras like spark plugs, coolant replacement, brake fluid replacement.. so on.
everything is listed in the owners manual with regards to when mercedes recommends replacing things... spark plugs, fuel filters..and whatnot.
depending on the year of your W202, you may or may not require the A and B services. The 1998 and newer cars use the FSS system.. the 1997 and older cars dont use this method to dictate when services should be done, but do go by the amount of miles you have.. each service for that is listed in you owners manual too.
