any pic..
Regardz,
J Irwan
For W202 owners, the european comes with a smaller door lock pins
Here is the part number
A 123 766 00 22
They are about $1-$2 each.
Past: 1997 W202 C36 AMG
any pic..
Regardz,
J Irwan
I think I got those pins. Is it the one from the CLK?
E55 2000
M-3 2014
pic... Jun, can you take yours?
but I have 1 style picture to show why european door lock pins are better:
When locked, nothing is sticking out.
click the link
As found on your NA Spec w208 as well. So a trip to your local dealer is all that is needed for these.
Yup! that's the one I got. I've checked the PN and it matches with the W208 door lock knob. I'll take pic in a while.
E55 2000
M-3 2014
Here's some pic of what we talking about here...
I think it got some kind of adhessive to lock itself when you install this door knob. Plug in and twist it once.
E55 2000
M-3 2014
Do these work on the W203 as well?
2006 xB - bubble tea mobile
1984 AE86 SR5 - project levin
1986 AE86 GTS - project trueno
Yes. This will work on W203
Woohoo!! Another "mod" which I already have!
1996 C280 - African Member #1
I went out this weekend and got thes door pins. They don't go down when I lock the door
Autostart Autostarter
Progress Rear Sway Bar
USDM Bodykit
USDM Foglights
1997 AMG C36 (RIP Thank God)
OEM Bosche Clear Corners
OEM AdvanteGarde Grill
Bilstein Sport Shocks
Eibach Springs
Zender rear lip spoiler
W210 mirrors
You have to twist to break a seal inside. So do the twist!Originally posted by Rocky
I twisted it but it won't go in. I even used pliers. Thinging about removing the door to put them on now
USDM Bodykit
USDM Foglights
Eibach Springs
W210 mirrors
when its closed is it somewhat down? Or you mean when you lock the door its still sticking up and hasnt moved at all?
it sticks up and doesn't move at all.
I think the hole is too small for this style of door pin to fit in.
USDM Bodykit
USDM Foglights
Eibach Springs
W210 mirrors
When you screw it in can you pull it off? I have these on my car and they work normally. It goes up and goes down.Originally posted by Rocky
Did your locks function prior to this?
when I screw it in..no i can't pull it off but it won't go down either.
yes my door locks work.
i think the hole is too small for some reason to fit the euro style pins.
USDM Bodykit
USDM Foglights
Eibach Springs
W210 mirrors
Thats funky.
that's weird,
the euro style pin should be smaller (if not the same) in diameter that the your OEM one..
btw this so called euro door lock pin actually standard on the older mercedes
E class pre W124
Regardz,
J Irwan
I'm not saying the pin isn;t fitting.i'm sure it fits..it's just the hole on the door that's a bit to small I think.
USDM Bodykit
USDM Foglights
Eibach Springs
W210 mirrors
You talking about the rubber around the hole that makes it look small?
E55 2000
M-3 2014
Rocky,
make sure you screw it on correctly. means the pins held into the rod.....
YepOriginally posted by JRE320
USDM Bodykit
USDM Foglights
Eibach Springs
W210 mirrors
