don't be a jerk... I am sick of fucking hearing it, you have good info and I just backed the info a search came up with... and back to the diffs you guys used the one from 202 Type, C230, Mexico, MT, 3.46 ratio? And you said minus replaceing the entire thing the most you can get is a 3.46, what would you replace it with? Hey man I'm a n00b when it comes to diff changes and gearing, just trying to figure some info out man cut some slack....
Another question jeff and some others ahve the kleeman lsdif I changed the ring and pinion to this c230 3.46 mexican type could I add lsd? And if not what would I have to change in order to add the kleeman lsd and a better diff?
