there is a bulb in the top of the unit should be a 5 min job.
hey my ac (digital for a 98 normal c230) lights seems to be faded, its much weaker than all the other orange lights...i was wondering is it a bulb...if so how hard is it to replace..
take out the a/c unit, like the radio, using the knife keys,
or a small knife and it should come out.
be careful not to drop the little white bulb socket, on the bottom of the unit , put your hand on the bottom of the unit when you slide it out, just to be on the safe side. take the bulb and replace it, and repeat the process
*u can search for most stuff abu* i just did and found this, i remember it as i posted in it bout chaging the color of the bulb and thus the color of the ac, havent done it tho just a suggestigion
thanks man, my bad
