Remove screws:
1 behind the chrome door handle
1 under the door pull
1 by the door latch
Unsrew your door pin (if youre using the w208 ones then no bother.
Start from bottom and pull door card away from door. It will make pop'n sounds and you will probably break some clips but that is to be expected.
Once you have done all of that you will need to pull up as the top portion of the card is held on by metal clips.
You will have some resistance while trying to pull up its normal.
And there you go.
