Results 1 to 19 of 19
Thread: which air filter is suitable for 97'202s and better?
    http://cgi.ebay.com/ebaymotors/K-N-A...28944638QQrdZ1
    or
    http://cgi.ebay.com/ebaymotors/MERCE...29411394QQrdZ1
    my friend said only the rectangle one would work but i wanna know if the cone one will work?
    Well I' ve heard to stay away from the K&N filters because they will wreck your MAF.
    2000 Volvo S70 GLT SE
    Mar 2005
    3
    I agree too. Try to stay away from K&N filters. They allow too much dust and rocks through. Stick with the OEM filter. Just my 2 cents.
    what are other alternative for intake if i cant choose Kand N?
    Nov 2004
    1,757
    there is nothing wrong with cotton gauze filters, as long as you dont over oil them.
    2002 S500
    2002 CLK430 w/ 5.5L swap
    2002 SLK32 AMG
    2003 S430 w/ 5.0L swap
    2000 ML55 AMG
    Re: which air filter is suitable for 97'202s and better?
    Originally posted by hideric
    my friend said only the rectangle one would work but i wanna know if the cone one will work? [/B]
    i m using the cone air knN filter, i have to say it does increase performance...it works.... the thing is i have a c180, which i dt think comes with the mas system, yet i saw lotta pple online swapping for cones...no 1 reporting a malfunction,as long s u dt oil it
    i doubt ur car dosent have MAS....
    as for the filter i had K&N and a OMP cone filter...decided to take them off cause didnt wanna risk frying my MAS for it....however it does add a nice sound to the car
    May 2003
    4,927
    every w202 has a MAF (MAS)
    Toronto, Canada
    2,244
    really now!!.. they allow alot of rocks through huh? I think you have some major issues if rocks are getting past your filter!
    I agree with jnenad16... as long as they arent over oiled.. they are fine.
    I am using a cone filter.. works great.
    its every how many miles should we re oil the filters ?
    Nov 2004
    1,757
    once oiled, its good for about 30K miles or so.
    2002 S500
    2002 SLK32 AMG
    2000 ML55 AMG
    and when i bought my oil filter..i felt that the oil was filtered already..it also came with a can and some cleaning devices....
    but for those looking for power i felt nuthing...
    well that's what i've been told by my local mechanic.....the c180 doesn't come with the mas system, it's a more simplified thing i think
    to abuimad:it was at "siyana" if u know it
    Oct 2005
    158
    There should be nothing wrong with using a K+N filter, you just have too make sure you do not put too much oil on it...way too many people freak out about it cause they don't know anything about it..
    Silver 99c230k
    *supersprint header(in process)
    *Remus full sound turbo cat-back exhaust(custom)
    *K+N performance filter
    *Avantgard grill
    jsut open your hood and u can see it clear as day if its there or isnt..and im pretty sure it is
    (no dont know it were is it located, and is it ne good)
    Sep 2005
    680
    c180's do have MAS.
    Jan 2006
    14
    K & N Filter
    I have K & N filter(rectangule) in my 97 C230....I have no problem with rocks, however didn't feel any extra power...
    Apr 2006
    251
    you guys are hilarious, how in the world do you get rocks into your filter hahaha
    I had K&N on.
    But I took it out and replaced it with OEM.
    It definitely made my Accel more sensitive.
    Right now, I feel like I'm now breathing through a cotton mask, but I know I'm much safer.
    Only problem I had with the filter was:
    When I tried to park my car after a high RPM drive, as soon as I shifted to "Park" gear, RPM jumped up to about 40-50(x100).
    I had to kick the gas pedal past that RPM to settle the crazy behavior. I personally thought that the filter just let more air through than the computer thought it was.
    95 C280
