Nice!
Any chance you could post the maker and part number?
Thanks
Nice!
Thanks
1993 ZX6E
1996 C36
1972 240Z
1993 Bayliner 1750
The one who dies with the most toys wins!
the part number that autohaus sells is 1002000715, and its made by behr if Im not mistaken.Originally posted by NISMOPOWERED
Nice!
Thanks
2002 S500
2002 CLK430 w/ 5.5L swap
2002 SLK32 AMG
2003 S430 w/ 5.0L swap
2000 ML55 AMG
oops, I qouted my self.Originally posted by jnenad16
the part number that autohaus sells is 1002000715, and its made by behr if Im not mistaken. its the same one I had in my 103 and 104 engines.
nenad![]()
2002 S500
2002 SLK32 AMG
2000 ML55 AMG
the ones I got were 79degrees. the only 80 degrees thermostats are for V8's, which are longer in length, and should not be used in I6's.Originally posted by omeyhomey
its a 80C thermostat from another benz model, i believe it was either a 202 or a S500, i forget which. same concept can be applied to 202s, fine a lower temp 202 thermostat, they are all interchangable
2002 S500
2002 SLK32 AMG
2000 ML55 AMG
I have the 70c stat too, still waiting on the install for it though, gonna do the fan switch, lower stat and fan delete all at once....
***C43***
i got the 70 too...first thing i did to my car, and it helped a lot
call me stupid, but i don't get it...how does the temp gauge make the car run cooler?? :bored: and if it works...i need it for my car![]()
normal stat opens at 87c this one is 79c which means it opens at 79c, and by open I mean let the coolant cool, at least that's what I think happens, makes sense to me
***C43***
the purpose of this mod is to lower the cooland temp, thus lowering the engine's running temp, which yields longer engine life and a bit higher perfromance output of the engine in two ways:Originally posted by OCKlasse
1. it decreases the chance of detonation in the cylinders, thus allowing higher timing advance
2. the intake air is cooler which increases performance by further decreasing detonation tendencies and by feeding the engine with a slightly cooler/denser air.
2002 S500
2002 SLK32 AMG
2000 ML55 AMG
DO you guys know which Part Number and Thermostat will work on a V-8, 113 engine to get the 79-80C temp.?
Thanks,
Jeff
the thermostat for your car comes as an assembly with the housing, the ones we are talking about are just thermostats, so it wont fit.Originally posted by speedybenz
Thanks,
Jeff
2002 S500
2002 SLK32 AMG
2000 ML55 AMG
Can I see a pic? I can remove my Thermostat from the housing so it may be possible!!
Thanks, Jeff
here is the pic from autohaus
2002 S500
2002 SLK32 AMG
2000 ML55 AMG
Be aware that the electric fan set point did not change and it is above the full open temp of the original thermostate.
In hot weather it will still go to the set point temp ??95 C.
The engine temp will flactuate between the thermostate open temp and the fan set point.
Large temp variation are not so good for the engine.
(expansion contraction). It is best to lower the electric fans set poin as well.
Thanks
How would you go about doing that?Originally posted by mercedesturbo
Thanks
1999 c280 BONe Stock
Very complicated. You have to fool the computer and make him think the temp is higher.Originally posted by smOKeSILVER13
In any case I see your car is 1999 c280 and I assume it is 203 body (V6) and not a 202 ?
thats what I did, I had a electric thermoswitch that was set a around 82C, and engine temp never exceeded that point, even in the hot, humid hawaiian traffic jams.Originally posted by mercedesturbo
Thanks
2002 S500
2002 SLK32 AMG
2000 ML55 AMG
So how could it be a 203 if it's an 1999 c280 w202?:hmmm: :werd:Originally posted by mercedesturbo
is it an easy DIY with a 230 non komp motor as well?
