Results 1 to 14 of 14
Thread: HELP! Oil leaking into coolant...
    Apr 2005
    2
    Hi,
    My car has a bad oil leak (head gasket) for some time. In the last week, I found that my car was running a little hot, but at other times it wasn't. I checked the coolant level yesterday and found that it has turned into an orange, oily liquid.
    I was told that this could be caused by oil somehow leaking into the coolant system. Does anyone out there know what can cause this and if it is fixable?
    Any advice would be hugely appreciated!
    Thanks,
    JC
    1996 C280
    You need a good mechanic on this...
    E55 2000
    M-3 2014
    May 2003
    4,927
    ouch.....
    Sep 2004
    525
    Umm, replace the head gasket.
    Nov 2004
    1,757
    no doubt.
    In Charge martattack's Avatar
    Jan 2004
    Kirkland, WA
    816
    Re: HELP! Oil leaking into coolant...
    Originally posted by jcowens2000
    Hi,
    Thanks,
    JC
    1996 C280
    YOu said it yourself at the beginning of the post. Your headgasket is bad. The oil is leaking into coolant passages in your head because of a poor sealing HG. It can be fixed by replacing the head gasket
    2012 535i
    2005 545i - Retired
    1994 C280 - Retired
    rollinrealbig
    Guest
    is it just me or do headgaskets seem to be a more common problem on C280's then the C230's and under ?
    May 2003
    4,927
    its that damn I-6
    Jan 2004
    Kirkland, WA
    816
    Particularly the M104 (Inline six) C280 had a headgasket problem because they are a hot running motor. It usually has to be replaced under 100k
    2012 535i
    2005 545i - Retired
    1994 C280 - Retired
    Sep 2004
    525
    If I am not mistaken, the issue with the head gasket was fixed. The design was changed, so after the head gasket is changed, it should not be an issue anymore.
    Jan 2004
    Kirkland, WA
    816
    Yes, the updated gasket (multi layer steel i believe) fixed the problem.
    2012 535i
    2005 545i - Retired
    1994 C280 - Retired
    Jan 2005
    164
    Once you get it fixed it sounds like you'll be good for a long time.
    - CS
    2000 C230K
    1998 Prelude Type SH
    1957 300 SL Gullwing
    1953 Porshce Spyder
    1963 Ferrari GT California
    1988 Dodge Reliant \"K\"
    They reinforced the front right corner (passenger side) of the gasket, which was the area of most common fault. Have a look at photo #1 on this link to see the difference.
    http://www.mercedesshop.com/Wikka/M104HeadGasket
    Apr 2005
    2
    Hi!
    Here's an update on my oil leak-coolant nightmare...
    I took the car to an excellent mechanic who discovered that the head gasket was indeed totally shot (u guys were right). He also found some hoses that were on the verge of bursting/deterioration.
    Since my coolant hoses were pretty much destroyed from the oil contamination, many of the hoses are to be replaced. The expansion tank was busted and was leaking at the base of the cap.
    Also found "control arm bushing" "idler arm bushing" and 2 ball joints totally destroyed/gone.
    Breakdown:
    Head gasket parts and labor: $1300
    hoses parts (no labor charged): $600
    Control arm, idler arm, ball joints ( parts and labor): $900
    Everything else in the car is in perfect working order. If I can get another 100k miles out of it, its worth every penny to me.
    btw, my car is a '96 c280, 200k miles. A/c still works ! lol
    Most awesome mechanic...he likes "conservative" repairs. He's in the Atlanta area. MDS Mercedes Specialist.
