nm
The instrument cluster, if I'm going to replace those bulbs with LEDs what size(s) do I need?
Thanks!!
1999 C230k Silver
Remus Sport Exhaust
18\" Damani Champ\'s Gun-Metal
Clear corners
White blinkers front and rear
Pioneer Head Unit
Custom projector fog lights
S600 grill
Debadge
12\" Alpine Type R
1250w Kenwood amp
\"ported\" trunk-to-cabin
MB all-weather mats
ugly ass steering wheel cover
really? why?
***C43***
I have no idea where you got that information but thats 100% incorrect. LED's emit ZERO heat and have far less chance of causing a fire than a normal incandescent bulb. Not only that they use 95% less electricity and last 10 times as long. Not only that but the LED bulbs you see already have the proper resistors built into the bulbs to prevent too much current.
If you do not know what you are talking about PLEASE do not post false myths and folklore.
:werd:Originally posted by omeyhomey
I have no idea where you got that information but thats 100% incorrect. LED's emit ZERO heat and have far less chance of causing a fire than a normal incandescent bulb. Not only that but the LED bulbs you see already have the proper resistors built into the bulbs.
***C43***
Has anyone identified what size/type of bulbs are used in the instrument panel ? I had a brief look at the bulbs before but i do not know the detailed specs.
LED's do emit heat, and so does the limiting resistor. It is a small fraction of the heat emitted by an incandescent bulb, but it is there nonetheless. If you find a LED that actually emits ZERO heat, the Nobel Prize Committee would like to talk to you.Originally posted by omeyhomey
My question is that LEDS dont really spread out light in all directions, they are like a linear light. I was thinking of putting leds in the instrument cluster but imagine that only certain points of the cluster being bright because thats where the led is most directed at and then other parts being dim. Hmmmm....
The garage::.
C 230 040 Blacked Out
Mods: 18\" monoblock, koni lowering springs,Debadged,Black headlight inserts,Custom Puddle Lights, Pioneer P6600,Euro Plates,LED interior lighting
Thank you....
E55 2000
M-3 2014
