Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Can't keep a "power brake" going in a '00 c280?
    Oct 2005
    143
    I was at a stoplight today and I wanted to piss off some ricer behind me in a FWD Celica who was racing their engine by doing a smokey.
    I switched off the ASR via the dash switch, applied the brakes and full throttle simultaneously and the tires began to spin. But every few seconds they would stop, then start to spin again and the process would repeat, before any smoke would appear, although the rear did step out.
    My question is, can this be fully defeated? Or, is this an ABS issue, which can't easily be defeated?
    2000 c280 Sport
    1991 190e 2.3 (sold)
    Jan 2006
    1,260
    I assume your car is automatic. This happened because the ECU changes gear every time your revs reach high levels and the car stalls. Put "2" in the gearbox and you ll be fine. Remember to change to "D" immediately after the second gear reaches high revs!!!
    Did you mean ESP switch?
    Jim
    >> My white Greek merC
    rollinrealbig
    Guest
    did it happen to be an old light blue celica w/huge wing in sacramento area?
    yea my MB does the same thing while I do burnouts!
    Oct 2005
    143
    The car has an automatic transmission. I know how to power brake. I guess I meant ESP switch.
    2000 c280 Sport
    Oct 2005
    143
    Haha. No. This was in AZ. A white 2001 ish Celica with baby blue vinyl tape on the hood.
    2000 c280 Sport
    May 2006
    1,028
    my 99 280sport has an ASR switch on the dash, but no ESP.....
    Jan 2005
    164
    Careful with the brake burnouts...only one wheel breaks out...may look stupid.
    Having said that, with ESP turned off I can usually do pretty good burn outs.
    2000 C230K
    1998 Prelude Type SH
    1957 300 SL Gullwing
    1953 Porshce Spyder
    1963 Ferrari GT California
    1988 Dodge Reliant \"K\"
    rollinrealbig
    Guest
    NOT always true w/mine!!!
    Ive notices that sometimes one wheel slips out fine with nice smoke and the other side slips through but not as fast! and I have no LSD, altough wouldnt mind having it to do sick burnouts and stuff, but that kind of fun costs too much LoL
    Oct 2005
    143
    I'll have to double check that.. I'm not sure the back end would've stepped out the way it did if both wheels weren't spinning at the same time.
    2000 c280 Sport
    Apr 2006
    251
    why would you want to do this? YOu're just going to end up braking parts....
    AMD64 3200 \"clawhammer\" 1600FSB
    Asus K8v-x MB
    1Gig Kingston Ramm
    240gig WD HDD
    ATi RAdeon 9700 Pro Vid
    Audigy SoundBlaster Pro Zs
    Logitech MX3k Wireless KB/Mice
    Altec Lansing 2.1
    Princeton 18.1\" LCD
    Lian Li Black Anodized Case
    Antec 750w PS
    Mar 2006
    1,889
    a Kleeman LSD is designed to provide much more balanced power to the wheels and is designed to launch a 600hp beast. i can't see how that would help you make better looking burn outs
    Apr 2006
    251
    that is why you get a stick shift
    Asus K8v-x MB
    1Gig Kingston Ramm
    240gig WD HDD
    Altec Lansing 2.1
    Antec 750w PS
    Oct 2005
    143
    I really don't give a shit...
    2000 c280 Sport
    Apr 2006
    251
    obviously....
    Asus K8v-x MB
    1Gig Kingston Ramm
    240gig WD HDD
    Altec Lansing 2.1
    Antec 750w PS
    Oct 2005
    143
    obviously....
    Yeah...
    2000 c280 Sport
    May 2006
    1,028
    the rear end is built to handle the strenght, it has little to do with helping/hindering a burnout.
    if anything, it'll be a little harder....BUT
    Having an LSD in your rear end means you will spin and smoke both wheels, rather than with an open diff and the "one wheel peel" or "one tire fire", which looks gay
    Mar 2006
    1,889
    i was just suggesting that i doubt he's going to break the rear tires loose with an LSD that's designed to make 600hp to the wheels hook up
    now a 600+hp w202.. that would be impressive!
    If I hit the ESP button on my dash and hold down the breaks while flooring it I'm pretty sure I do a full burnout. No one has ever told me that only one wheel is spinning.
    2000 C230K Sport
    - Clear Corners
    rollinrealbig
    Guest
    ya i fully agree ... but good luck finding a 202 w/manual in the US!
    the whole point in burning out is just for the hell of it - if your really mad at something, you do donuts and burnouts and if your in a really Hyphy mood you also do donuts and burnouts! LoL
    Jan 2005
    564
    this is what my c230k does when I turn off the ASR and powerbreak.. both wheels usually spin too
    http://www.pbase.com/alphanumeric/image/49035279
  21. #21
    Oct 2005
    143
    Hmm. Interesting.. Although, it looks like the right rear dug in deeper, as if it was spinning the most.
    One of these days I'll have to do one on the asphalt, take a picture of the results and post it.
    2000 c280 Sport
  22. #22
    May 2006
    1,028
    I could do that in a 1.0L 3 cylinder geo metro. Both your wheels probalby wouldn't spin on say, a real road.
  23. #23
    My previous 99'230K would spin both no problem using the brake. Probably only did it twice though.
    Please don't ever rip it up in dirt...it's just bad. Rocks kicking up everywhere, dust, etc....not good. Sand in the road sucks too. Any car will spin em' but sand goes everywhere and stuff.
    On another note, my car leaves a good set of strips if I floor it just right. Flooring it around corners with the ESP off is the best. Usually can hold the car sidways for a good 20 feet or so. I'll try and get a video of it sometime.
    THE MOTHER OF ALL IS THE "ROLLING BURNOUT"
    This is when the car is in motion rolling at slow speed and flooring it breaks them loose into a burnout. True test of a cars sac. Mucho Tourque.
    I hope mine will do this soon......
    .....I drive sideways.....
    *98\'C43 Supercharged
    *H&R springs
    *Bilstien Shocks
    *Magnecore race wires
    *Phelonic intake spacers
    *Bosche Clears
    *Custom 3in stainless exhaust
    *Renntech Monolite 18\'s
    *Some other stupid stuff
    http://i88.photobucket.com/albums/k198/nitrogenbalance/0801.07pics054.jpg
  24. #24
    Feb 2006
    199
    thats EXCTALLY what i was thinking.:ermm:
    btw esp and asr are two different things...
    2004 S500
  25. #25
    Oct 2005
    143
    Werd. I don't think I'll ever acheive this with my NA 2.8l c280 however...
    2000 c280 Sport
