Results 1 to 19 of 19
Thread: Silicone Elbow + Crankcase vent bypass complete
    Guest
    Dec 2005
    883
    Silicone Elbow + Crankcase vent bypass complete!!
    Hey guys.
    I have finished the silicone elbow project finally. You guys have seen the old pictures but now I finally finished the crankcase vent bypass as well. What this does is it makes sure that all 100% of the air entering the engine passes through the Air sensor so the sensor can accruately gauge exactly how much air is coming in and as a result it improves your Air Fuel Ratios.
    The Crank case vent is an emissions deal and it essentially is a controlled vaccum leak, it makes all the oil vapors go back into the engine and reburn them. This however also is air that does not pass through the MAS and as a result it can cause lean conditions. By putting a K&N breather on there instead of routing it back to the intake it can be filtered out and the filter air can then pass out into the atmoshpere. In addition, this also improves overall running of the car as well.
    Performance: I honestly was not expecting any gains from this but wow was i pleasantly suprised. The car is NO longer knocking or running lean and torque had jumped up a significant substantial amount. in addition the car idles better now (though at first it will idle rough the first 10 seconds as the car gets used to the new extra air coming in at idle). The mid range power is significantly improved and now my EGR problems went away (go figure). So this solved MANY of my problems. and now I should be getting a dyno very soon after I have my custom high flow midpipes installed, and I am expecting serious gains. Anyways here at the pics, enjoy
    Mar 2006
    1,889
    can you piece together a parts list? i am extremely intersted in your setup for my C230K!
    who did the carbon fiber intake for you? i remember you posted a thread about it and the guy never came through.
    how much for you to build this setup for me? (i really dont have the time, but i've got the cash np!)
    Guest
    Dec 2005
    883
    Hey PG,
    The filter is made by Ractive and it cost roughly $15-20. The K&N breather can be found at any autozone/pepboys for $9.99. The silicone elbow was $19 + $6 shipping. so realistically for $65-70 for everything will get you a good instake system. Hope this helps.
    3,221
    Nice Intake!!...value for money for sure!...
    so i guess there is no oil present in the blow- by?
    also iv never seen an engine have a crank bypass return after the air flow device of sorts...is this only on the AMG engine?
    Also another reason for the vent return to the intake is to create a vaccum under load and aid it,or so my manual said.
    though i have also removed mine from the intake!.
    Paul
    Guest
    Dec 2005
    883
    Paul
    Hi paul, you know i was anticipating some oil too on the crankcase vent but to my suprise... NONE.
    most european cars have them after the filter so the oil vapors don't ruin the air filter i assume, its also the reason why so many european throttle bodies get all gross & disgusting so this should keep your throttlebody cleaner, much longer.
    Really as far as aiding the vaccum it doesnt do much. This mod really helps out the low end b/c thats where the MAS is most sensitive when it comes to low air volume. this will really help boost the low end up to around 5000max, after that i still have the dame top end and it still dies off too early (around 6000rpm-6800rpm.) Once I do the high flow midpipes it should solve the high end flow. Dyno coming not this week but the next week .
    Guest
    Dec 2005
    883
    Hey guys,
    Finally got back from a drive around town with the ECU reset, the new Silicone elbow kit complete (including crankcase vent bypass), and Toulene in the tank and the car run absolutely amazing, the car has never had this much mid range torque EVER. Finally the car is running really good. The top end is still choked at 6000-6800rpm but I have a feeling the new high flow midpipes will completely change that. Its almost in S420/S500 V8 territory as far as torque is concerned. Once I finish everything i should hopefully have a dyno by the end of the week at the latest! The project is nearing its completion guys, i can't wait to see the final dyno . anyways, ttyl.
    Jul 2005
    SF Bay Area
    1,540
    Re: Silicone Elbow + Crankcase vent bypass complete
    What is that? Looks funny, like a little mini intake for the engine.
    1997 C280 Sport
    Nov 2004
    1,757
    thats the breather. I did this on my C280, but it was somewhat different. the breather hose on my car was located behind the water pump, on the block, not the head as on the omey's car. however, after doing the mod, I did not see any noticable gains, and the throttle body was still getting dirty as often.
    2002 S500
    2002 CLK430 w/ 5.5L swap
    2002 SLK32 AMG
    2003 S430 w/ 5.0L swap
    2000 ML55 AMG
    3,221
    Hey,No oils a good sign!...you should see what my diesel spits out!...
    seems like you've got it all together man,cant wait to see some dyno results!!!
    Jan 2005
    564
    and doing this wont blow out my rear main seals? hmmmmm
    Nov 2004
    1,757
    why would it do that? the pressue is still being relieved, but not through the intake.
    2002 S500
    2002 SLK32 AMG
    2000 ML55 AMG
    Guest
    Dec 2005
    883
    well my situation is very different b/c the air fuels ratios are off so for me the gains would be more noticed than regular but if you plan to do a silicone elbow its definitely a worth while mod in my opinion. Plus you can do everything for under $50 including the silicone elbow
    3,221
    interesting thing that....i guess depending on the condition of your rings etc,blow-by would be somewhat high at 6000rpm...and thus could cause oil leakage around the crank seals if venting was poor...just a thought though.
    though i can say for sure removing the vaccum affect would definatly increase crank case pressure in the higher rpm...
    While where on the topic...i just remebered the M111 does take a small portion of air from the crank case that bypass's the MAF at idle,they are located between the intake ports on the head,but they are restricted to two 1mm holes,so airfow is minimal,there still fill of crap oil though.
    Guest
    Dec 2005
    883
    on the M104 its not 1mm its a 5/8's gaping hole, its pretty huge. As far as pressure. the pressure is still releived guys its just releived into the atmosphere thats all. it should have no affect on seals and etc.
    Guest
    Dec 2005
    883
    hey guys, also i noticed something else. with this new mod for some reason resonance has subsided a decent amount to the point where i actually notice it. maybe the change in A/Fs has slightly changed sound as well. either way just an observation i noticed.
    The custom high flow mid pipes + high flow cat + magnaflow resonator go in tomorrow !!
    Will this exact set up work on a C230 Kompressor?
    2000 C230K Sport
    - Clear Corners
    Mar 2005
    245
    Not teh same exact system. you would have to make a flange for the bypass and then put a filter on it. Dont ask me why it needs it, but i figure since it had it before in teh airbox, i just played it safe and set up a filter on the bypass. i did notice more s/c whine and quicker throttle resopnce. and when you on boost and let go of the throttle, it sounds like a forced induted blow off.
    May 2006
    347
    sorry to revive an old thread. but omey could you repost the pictures? I'm trying to figure out my cai right now.
    Guest
    Dec 2005
    883
    I'm on vacation right now but when I get back I will try to find them. thx
