get a wiring diagram and look it up. as far as I know, speed signal has always been green wire in most benzes, but I am not sure about your car.
Does anyone know the color(s) of the VSS. I hvae a 2000 C230k. I have read its a green wire, but there are about 45 green wires in the harness. Im upgrading to a nav unit so i need that wire. When you answer, just so i can under stand you you say, format is like so: green(or what it may be the clolor of the wire) with (color of the stripe running down it)
Thanks
Roca
2002 S500
2002 CLK430 w/ 5.5L swap
2002 SLK32 AMG
2003 S430 w/ 5.0L swap
2000 ML55 AMG
Where can i get one, i have been looking but can seem to find one anywhere.
www.alldatadiy.com
2002 S500
2002 SLK32 AMG
2000 ML55 AMG
there is a speed sensor wire that goes to ur head unit already, its the green one w/the red stripe
I'd go with crazy00c230k since he's got the same car.
Just in case though...
starting MY 1994 up to MY 2000: C230 Kompressor.
MODEL 202 as of 09/01/97 with CODE (810) Sound system
MODEL 202 as of 09/01/97 except CODE (810) Sound system
It's Green and Violet in those on Pin 1 of the radio harness of these systems.
Ok, i got a wireing diagram and there are a pair of wires coming out of the VSS sensor to the ESP control module. From that come a green and purple wire to the radio. the the green and red wire coming from the headunit is labled a "Data link connector". Im not sure, but by the looks of it, it seems like the green and purple seem to be it, if you have notice otherwise then please speak up.
Sorry dude. The VSS input is green and white for my 94 c220.
Hopefully someone else will know for sure.
