Ooooh, looks nice
Finally got the JE forged pistons!...As always heres a few pics to keep those who are interested in the loop....
The copper colour is a ceramic coating...
Here you can see the moly coat,thicker oil ring,contact reduction grooves and accumulator grooves(dont ask me accumulator grooves do...somthing about total combustion of the mixture)
From the bottom you can see the different structure against OEM....the JE piston is around 30g lighter than the benz item,which does equate to a decent loss in reciprocating force!
Pistons are off to the engine builders tomorrow..hopfully will get the engine back and in by next weekend!
Interesting coversation for today:
-I met a guy who sevices MB and races a 5.6L 500SEC..he believed "the OEM high pressure cast piston i had would be good for upto 400hp"
-My OEM ECU is not tunable in any way...well i guess thats confirmed!
-My engine balancer was disapointed i had the rods shot peened because he believes the big ends will be warped which will require machining and thus another ballance....
quote for today:
good advise may not always be good advise!
Paul
Ooooh, looks nice
1995 C36 ///AMG
hey hows tha 36?fix the faults?Originally posted by benzboy
Ooooh, looks nice
Will be fixed in sept, as have sold the 280, paid off credit card and large chunk of loan and such, really looking forward to fixing it, loses some of its coolness when you rock up and it has lumpy idle and sounds like a diesel![]()
1995 C36 ///AMG
all good...yeh man get it fixed asap!...would like to see it some time!...maybe when mines going next
So these pistons and rods are still spec to OEM, or did you change them to get a different displacement?
hella nice!! keep up the good work! i cant wait to see the completed results!!
we kept the same displacement!,the biggest change has been in wieght...with each new piston and pin combo being 41g lighter than the OEM items!,plus upto 8 grams on three off the rods...when i get around to it i'll calculate just how much less reciprocating force that equates to at 6000RPM...you will be suprised!...
Awesome! Waiting fo the numbersOriginally posted by 23K
we kept the same displacement!,the biggest change has been in wieght...with each new piston and pin combo being 41g lighter than the OEM items!,plus upto 8 grams on three off the rods...when i get around to it i'll calculate just how much less reciprocating force that equates to at 6000RPM...you will be suprised!...![]()
definitely time to bump up the revs![]()
search. think. do. post.
quote for today:
Paul
Will those work on a c280?
*STATUS*
just as soon as i...err...find my calculatorOriginally posted by Denlasoul
Awesome! Waiting fo the numbers![]()
formula
basic calculation shows an 8% reduction in reciprocating mass
Na man,there customOriginally posted by STATUS
I dont see any pics!
2002 S500
2002 CLK430 w/ 5.5L swap
2002 SLK32 AMG
2003 S430 w/ 5.0L swap
2000 ML55 AMG
its tempting!Originally posted by Renn 208
look harder!...jksOriginally posted by jnenad16
they there for sure man!
where can i get some custom ones?Originally posted by 23K
Na man,there custom
*STATUS*
How much did these cost?
You can PM me the price.
edit: So if you bring up your redline, how does that work with the speedo? For example, if my car has a 5800 redline and I raise it to 6200, how do I get it to match my speedo when there is an actual redline mark on the speedo at 5800? New cluster or something?
I tried with firefox, IE, and netscape, no pics. seriously.Originally posted by 23K
look harder!...jks
2002 S500
2002 SLK32 AMG
2000 ML55 AMG
ya pix only worked for about a day. then disapeered.
Contact top-end performance!....
Any reason why you would be wanting forged pistons?
Weird...they are working today and have every time iv logged on....maybe cardomain was down for a while?!?!Originally posted by jnenad16
you got PMOriginally posted by Denlasoul
You need to watch more Initial DOriginally posted by Denlasoul
edit: So if you bring up your redline, how does that work with the speedo? For example, if my car has a 5800 redline and I raise it to 6200, how do I get it to match my speedo when there is an actual redline mark on the speedo at 5800? New cluster or something?![]()
I dnt get why they even bother putting a redline.Originally posted by Renn 208
You need to watch more Initial D![]()
