Results 1 to 16 of 16
Thread: W140 s500 brake calipers on fit W202 ?
    Feb 2011
    988
    W140 s500 brake calipers fit W202 ?
    As the title says will the larger W140 s500/ s600 4 piston brake calipers fit or is it possible to fit them to a w202 ? has anyone ever came across this swap. Heard of this swap ? have pics or write up possibly ?
    Jul 2006
    Philadelphia/South Jersey
    1,547
    Those are the C36 calipers from a 96/97 (sl600). cant tell how similar they are, but maybe you can find some more pics of the S600 ones and cross reference...
    Drexel Business '11
    Senior Member W202FTW's Avatar
    Jul 2011
    Boston, Massachusetts
    282
    You'll need the caliper anchor and a matching rotor to see if it'll truly bolt-on.
    2001 Mercedes E430 Sport
    2009 Toyota Camry Hybrid
    Feb 2011
    988
    Quote Originally Posted by anf6789 View Post
    is that the part number to the face of the caliper in the picture you have posted ? I think im going to just grab the calipers and rotors and see if it will bolt up and if so then purchase better rotors , rebuild the calipers and paint them.
    Quote Originally Posted by W202FTW View Post
    Is the caliper anchor part of the hub assembly ? And of course will need new rotors as the ones on the w140 look way larger than mine. But how do i know weather or not they will work entirely? if they bolt up and fit. Will my brake booster , ABS, and all the brake system components work with them as well ? Given that I have a 96 and most the w140s in the yard are 95-97 it seems like. it should be almost a direct swap if not one already.
    Aug 2012
    SoCalif
    1,011
    Quote Originally Posted by SD202 View Post
    Constintin, there is a little more to it then that. You have to worry about caliper offset, caliper radial mount height, and rotor width & offset. There is also brake bias front to rear and you will throw off your braking combo vlave proportion front and rear. The car is designed with a balnced setup. You also need to deal with the master cylinder volume that needs increasing with the larger volume calipers. More fuild volume in the caliper means more fluid volume in the MC that needs to be pushed or else you have a longer traveling brake pedal and possible unwanted low brake fluid light as a result of that longer travel.
    Just food for thought and things to look out for.
    Dean
    Jul 2006
    1,547
    SD its not the PN# i believe its the piston sizes in mm if i remember correctly. i'm not sure if the C36 has a bigger brake booster ect. or not. Maybe a little bit of research will give you the answer. though there isnt too much known about the braking system of the C36.... AMG basically put whatever they had laying aroung on the cars. Took me 2 weeks to find the rear brake pins..at $8 a piece for 4
    Drexel Business '11
    Dec 2006
    Norcal
    2,864
    Those do NOT directly bolt up.
    Feb 2011
    988
    Thanks Rkd. Exactly the answer i was after.
    Aug 2012
    SoCalif
    1,011
    They look to me like they will bolt up to the spindle without modification, its more of an issue of if the rotor will fit also (inner and outer bearing sets) and what final hub face offset will be compared to the stock configuration. I am willing to bet the caliper AND rottor combo together will in fact bolt up since they would be the same width and radial mount hieght.
    I have done alot of internet checking on pictures that appear on parts wwebsites to have the same mount lug spacing whereas these and the stock calipers look very simular in offset and spead. these look to have longer lugs for the larger rotors.- but this is merely an observation that I will need to buy a few parts to check actual fitment when I am ready for that.
    I am curious if there is any other known fitment upgrade without machining parts?
    I have done a few very wild things with aftermarket brake setups on cars ( track built street cars that is). I would not plan to go so expensive for fancy with this daily driver other than a simple bolt on upgrade if possible. Here is an example of a setup I built for m old Camaro where I went from a single piston 10.5x1.0 rotor to an elaborate 6 piston radial mount 13.06x1.25 setup. I used to have access to a bridgeport CNC machine where I made everything myself- but no longer have access to that
    Dec 2006
    Norcal
    2,864
    I have ran across this situation, I was handed down a pair of 95' S500 W140 calipers and I ran home jolly to find out bloody things are no where near possible to bolt to the spindle.
    sorry to burst yee bubble but save the gold coins for something else! I may have another pair of stock C36 calipers for sale if anyone interested PM me Ill make it happen.
    white 97' C230 (sold)
    white 94' C280 (sold)
    white 98' C43 (sold)
    Tektite 03' E55 (sold)
    Black 86' Porsche 951 (sold)
    Black 98' C43 (sold)
    Dec 2006
    Leesburg, FL
    219
    How thick is the stock C36 rotor?
    202.029
    Jul 2006
    1,547
    http://www.ebay.com/itm/97-MERCEDES-...2617f6&vxp=mtr
    http://www.ebay.com/itm/97-MERCEDES-...item23272617f5
    c36 front calipers ebay $40 a piece someone jump on it
    seller also has the 3.6 amg m104
    Drexel Business '11
    Jul 2011
    282
    Those are all bolt ups right? I'd hate to have to buy a whole steering knuckle...
    Jul 2006
    1,547
    ive heard the front hub is different, i believe there is a recent thread on the forum that explains this. a thread about a c36 swap in a c280 i'm pretty sure.
    ....found it
    http://www.club202.com/forums/showth...-C36-into-C280
    Drexel Business '11
    Feb 2011
    988
    ....found it
    So I own a 6/1996 production date W202 C280 does this mean I have the updated style of hub that is from the 96/97 c36 AMG ? so in the case of my car and hubs these would bolt up with no other modification other than a larger rotor ?
    Jan 2004
    San Francisco
    786
    In your case you have the later hubs so you would just bolt up the larger rotors and the calipers. About the easiest swap out there. As a reference point my 96 C36 with a production date of 9/95 has the later hubs.
    1994 C280
    1996 C36
    2005 C55
    2013 Volvo XC60 R-Design
    1999 Porsche 911
