Quote Originally Posted by CJP28 View Post
I want to install a staggered set of 18" wheels on my 1999 C230 Kompressor, the front wheel size is 18x8.5" Offset 30 ET and the rear wheel size is 18x9.5" Offset 35 ET. Center Bore is 73.1 Will this set bolt on with no problem? Or will I have to do modifications? Thank you.
You will be fine with these sizes, btw are these "STR" wheels? I'm a wheel dealer if you're looking to purchase wheels. You will need conical lug bolts and hub rings. Also make sure you check what type of calipers you have because some of the mesh design wheels don't clear 4 piston brakes on newer 99+ w202s.
